Currently when you build a VI the bit file path is stored as relative (you can see it in the project XML). This means if you change the project location either:
You have to recompile the FPGA to use VI mode or run interactively. It seems the bitfile could be stored as a relative path like all VIs in the projects.
Cheers,
James
