Currently when you build a VI the bit file path is stored as relative (you can see it in the project XML). This means if you change the project location either:
- Moving machines.
- Checking in and out of source code control on different machines
You have to recompile the FPGA to use VI mode or run interactively. It seems the bitfile could be stored as a relative path like all VIs in the projects.
Cheers,
James
James Mc
CLA and cRIO Fanatic
My writings on LabVIEW Development are at devs.wiresmithtech.com
