This might have already been asked, but I couldn't find any posts.
X-Nodes are huge in comparison to the size of a subvi or most anything else on the block diagram of code, so lets shrink them down.
Can we remove the Read/Write box? We already have the little triangle to tell us the function/direction.
Can we use the node name instead of the generic term Data/Element? It's already there.
From there we can model it after a property node using references instead of error lines or we can model it after the IO node which is a little cramped but gets the job done. Both options retain a purple/pink bar to help identify it's X-node-iness.
