12-01-2018 10:52 AM
I have installed the "Field R&S Services" Logger library via the VI Package Manager for LabVIEW 2018. All works fine but when I create an Application (.exe) and try to run this on another machine that only has the LabVIEW runtime installed I get the following error:
Invoke Node in Logger.lvlib:File Start.vi->Top-Level.vi <APPEND> The front panel for <b>Z:\work\git\builds\LabviewLogging\My Application\LabviewLogging.exe\1abvi3w\vi.lib\Field R&D Services\Logger\Public\Action-Status\File Run.vi</b> could not be loaded but is required by this property or method.
The vi it is referring to exists in the Field R&S Services Logger library and contains a static vi reference that has me thinking is the reason that vi is not present
Does this mean I have to create an installer? Or is there something simpler that I can do in order to avoid having to run an installer each time I want to test my application on a target machine.
12-01-2018 03:20 PM
In your application builder do you mark the VIs that you load dynamically as "Always Include"?
12-01-2018 06:02 PM
Okay, I found something that worked on the lavag.org forum:
https://lavag.org/topic/14151-build-specification-enable-debugging/?tab=comments#comment-85259
All I had to do was the first bullet point - set "Show front panel when called" for the vi 'File Run.vi' in the library directory (C:\Program Files (x86)\National Instruments\LabVIEW 2018\vi.lib\Field R&D Services\Logger\Public\Action-Status\File Run.vi) and it worked!
