Application Builder and Library Dependencies
I have installed the "Field R&S Services" Logger library via the VI Package Manager for LabVIEW 2018.  All works fine but when I create an Application (.exe) and try to run this on another machine that only has the LabVIEW runtime installed I get the following error:
Invoke Node in Logger.lvlib:File Start.vi->Top-Level.vi
<APPEND>
The front panel for <b>Z:\work\git\builds\LabviewLogging\My Application\LabviewLogging.exe\1abvi3w\vi.lib\Field R&D Services\Logger\Public\Action-Status\File Run.vi</b> could not be loaded but is required by this property or method.
The vi it is referring to exists in the Field R&S Services Logger library and contains a static vi reference that has me thinking is the reason that vi is not present
Does this mean I have to create an installer? Or is there something simpler that I can do in order to avoid having to run an installer each time I want to test my application on a target machine.
(3,235 Views)
In your application builder do you mark the VIs that you load dynamically as "Always Include"?
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,206 Views)
Accepted by John80
Okay, I found something that worked on the lavag.org forum:
https://lavag.org/topic/14151-build-specification-enable-debugging/?tab=comments#comment-85259
All I had to do was the first bullet point - set "Show front panel when called" for the vi 'File Run.vi' in the library directory (C:\Program Files (x86)\National Instruments\LabVIEW 2018\vi.lib\Field R&D Services\Logger\Public\Action-Status\File Run.vi) and it worked!
(3,190 Views)
