Data is not acquired because of an VISA error!!
Place the probe THEN run the program.
Like I said I have seen that error a zillion times and it was always the spec tht I used.
Ben
Message 11 of 40
(701 Views)
How should I get rid of it? Because if I still have this error, the data won't be acquired.
Message 12 of 40
(699 Views)
For give me from asking but are you more comfortable asking questions in another langauge other than English?
If you feel more comfortable using another langauge please do so. I suspect the people who volunteer here can handle most languages so please do not limit yourself because of English.
Trying to help,
Ben
Message 13 of 40
(694 Views)
Well so far English is my best language for communicating after my mother language. I can speak german too but far worse than English. You have some problems with understanding my English?
Message 14 of 40
(690 Views)
Yes sir.
You posted;
What is "it" that you want to get rid of?
the probe, the error what?
TO get rid of the error you have to pass a valid VISA specifier.
To determine what specifier you are passing you place a probe on the wire prior to the VISA config BEFORE you rn the program.
Just abort out any eror messages you are getting and figure out what is in the probe.
I'm very sorry if this reply seems patronizing but this should be a straight forward exercise to verify what VISA spec you are using but here we are a dozen posts deep and we still don't know what the spec is.
Ben
Message 15 of 40
(685 Views)
You seem to have a problem understanding questions posed to you.
Please get your act together. The VIs you posted are broken. The top level is calling a VI that you did not include (vi connection 1). The one you did include (vi connection) is also broken. Obviously, you are running completely different code than what you provided so how can you possibly expect any real help.
Message 16 of 40
(683 Views)
Well this is why i would like you to see my vi because it might be the problem with dataflow or vi assembly. However as you said my vi is broken, what did you mean? Because I can execute the program without any problems. It just didn't work in the way I want. The VI connection is broken because i took it out from my previous sub vi which contain a while loop. Then I put this modified sub vi into Assembled VI in the while loop that exists already, and then connected it to visa serial. I am not sure if it's right or not.
Message 17 of 40
(668 Views)
It's a very simple concept. Opening your example results in a broken run arrow. As I said, your top level VI is calling a subVI that you did not include. You did not post the VIs that you are able to run. Fix the problem with your attachments! It's trivial to verify your attachments. Download them yourself and see.
Message 18 of 40
(664 Views)
I am so sorry that I didn't attach my main sub VI that the top VI is calling. Hope this VI is what you were asking for. The top VI should be able to run after downloading this VI
Message 19 of 40
(654 Views)
@Ben
I already put a probe on the error-out wire which I found before there was an error before running the program to watch what specifier is passing through that wire. It just showed the same error that I saw before. I still don't know what I should fix on my code.
I think it would be ideal if you can take a look at my VI.
Sorry if I gave any stupid replies but I really don't know what to do, besides following your suggestions straightforwardly.
I am quite new for Labview too.
Message 20 of 40
(653 Views)
