08-13-2015 03:07 PM
I have an ethernet connected device that I can ping in the CMD window but NI MAX says that it is not present...
How do I get NI MAX to detect this device as Present?
What am I missing?
Solved! Go to Solution.
08-13-2015 03:19 PM
08-13-2015 03:27 PM
I'm going to ask a basic IT question (questions that you're like... yes, I already did that). Did you verify that that IP address is not being used by something else? Unplug and ping?
08-13-2015 04:02 PM
What is the device that you are trying to connect to?
A NI device ?
08-14-2015 07:07 AM
Yes the device times out when I disconnect from it and ping then device.
Thanks for the response
08-14-2015 07:20 AM
NI device ?
It is a custom amplifier designed by the company that I work for. This device can be communicated to by some utility software
but I wish to automate this with Labview. Because this is an ethernet device, it does not sow up in Windows 7 Device manager
and more importantly, it is not found in MAX.
The MAX screen shown below states that it is a TCP/IP VXI-11 Instrument. I know that it is a TCP/IP device but am not sure what a
VXI-11 instrument is...
Do I need some special driver for MAX to see this device?
Thanks again
08-14-2015 07:40 AM
08-14-2015 12:59 PM
Thanks Dennis...
How do I use a ":RAW type of connection"?
08-14-2015 01:16 PM
Got- Thanks Dennis
