Excel Find and Replace VI error
Hi:
         I am using Labview2018 with Report Generation. My PC is running Win10 and has Office2016 installed. I happened to find that "Excel Find and Replace.vi"  is error.
        Does anyone konw the reason? This Vi is original.
Message 1 of 17
(6,687 Views)
What does the error dialog say when you click on the broken run arrow?
Message 2 of 17
(6,665 Views)
However,LV2017 has no such problems
Message 3 of 17
(6,651 Views)
The problem may be caused by 32-64bits.
Office2016,64bits
Labview2018,32bits
Message 4 of 17
(6,647 Views)
Accepted by zhaoqing-zhou
I reinstall Office2106-32bits,and Labview2018-32bits。
The problem get sloved。
I wish Labview switched completely to 64bits。
Message 5 of 17
(6,615 Views)
Accepted by Kristi_Martinez
Just responding because I had this same problem, but do not have the flexibility to install a 32-bit version of Office.
I was able to resolve the error by going to the block diagram and re-selecting 'Replace' on the invoke node.  This had the effect of adding another field to the node, and once that was there, the error resolved.   I had to do this for both polymorphic instances (str and num) in order to completely resolve the issue.
Message 6 of 17
(6,338 Views)
tbilir, thank you for your answer, it is very helpful to the problem I encountered!
Message 7 of 17
(6,201 Views)
Thanks, this was a big help
Message 8 of 17
(5,978 Views)
I have installed LB2017 ,64 bit and Excel 2016 ,64 bit, I was facing the same error ,just follow your instruction, just Relink the Invoke Node that problem was solved .thanks for your update. Now able to Build a EXE file.
Message 9 of 17
(5,772 Views)
I know this is an older thread, but thanks for the solution to reselect "Replace."  It worked for me.😀
Message 10 of 17
(5,573 Views)
