I;m having problems reading from an I2C device
Eric,
  Sorry for the late reply - had to deal with Hurricane Sandy.
  I didn't get the attachment. Can you please repost?
  Thanks!
   TheLT
Message 41 of 48
(1,021 Views)
Hi TheLT,
Sorry, I forgot to add the attatchment.  It should be below now.
Sincerely,
Message 42 of 48
(1,006 Views)
Eric,
  Ok, I think I see what the problem was - we were reading in 255 bits! That's why it was taking so long to update!
   I've attached new code - I think my problem is solves and I'm on my way - just have to deal with Sparkfun now about the magnitude of the magnetic field.
   Before I close off on this issue, can I get your thoughts?
   Thanks!
   TheLT
Message 43 of 48
(988 Views)
Hi TheLT,
Looking at your newer code compared to your previous versions, I am not sure what has changed, other than doing a write inside of the while loop rather than out.  However, if this is working for you in a timely fashion, then it should be ok to stick with.
Sincerely,
Message 44 of 48
(983 Views)
Eric,
  Sorry, you're right - I was getting confused with another version of the code. So yes essentially we just moved a write inside the while loop and that sped things up a lot.
  If you want me to PM you the Applications Engineer that was helping out in addition to you, please let me know and I will do that.
   Thanks!
    TheLT
Message 45 of 48
(967 Views)
Hi TheLT,
Unless that service request is open still, then it's not really necessary.
Message 46 of 48
(954 Views)
Eric,
   Just PMed you.
   Thanks!
    TheLT
Message 47 of 48
(951 Views)
There was a user by the name of "1Luc" who wanted a 2011 version of this code.
If this person can post back, I will post it!
Thanks!
TheLT
Message 48 of 48
(926 Views)
