10-31-2012 08:27 PM
Eric,
Sorry for the late reply - had to deal with Hurricane Sandy.
I didn't get the attachment. Can you please repost?
Thanks!
TheLT
11-01-2012 08:33 PM
Hi TheLT,
Sorry, I forgot to add the attatchment. It should be below now.
Sincerely,
11-06-2012 01:48 PM
Eric,
Ok, I think I see what the problem was - we were reading in 255 bits! That's why it was taking so long to update!
I've attached new code - I think my problem is solves and I'm on my way - just have to deal with Sparkfun now about the magnitude of the magnetic field.
Before I close off on this issue, can I get your thoughts?
Thanks!
TheLT
11-06-2012 02:29 PM
Hi TheLT,
Looking at your newer code compared to your previous versions, I am not sure what has changed, other than doing a write inside of the while loop rather than out. However, if this is working for you in a timely fashion, then it should be ok to stick with.
Sincerely,
11-06-2012 09:24 PM
Eric,
Sorry, you're right - I was getting confused with another version of the code. So yes essentially we just moved a write inside the while loop and that sped things up a lot.
If you want me to PM you the Applications Engineer that was helping out in addition to you, please let me know and I will do that.
Thanks!
TheLT
11-07-2012 07:34 PM
Hi TheLT,
Unless that service request is open still, then it's not really necessary.
11-07-2012 07:41 PM
Eric,
Just PMed you.
Thanks!
TheLT
11-30-2012 11:38 AM
There was a user by the name of "1Luc" who wanted a 2011 version of this code.
If this person can post back, I will post it!
Thanks!
TheLT
