LabVIEW 2012 Installation Error Connecting to Server
I am trying to reinstall LabVIEW 2012 after I.S. replaced my laptop.  The new laptop doesn't have a DVD, so they uploaded the DVDs and transferred the DVD files to a folder on my desktop.
Selecting the option to connect to NI to verify my serial number, I enter it and select "Next >>."  I immediately get an error message saying "An error occurred on the server.  Would you like to try again?"
That is as far as I can get.  If I click "Yes" I get the same error.  Can anyone point me in the right direction?
(This is a Windows 7 computer)
Thank you,
oxfat
(4,060 Views)
Accepted by topic author oxfat
Oxfat,
 There could be a couple of issues going on because of the age of the LabVIEW install and because of the physical media it's being installed from. I believe the easiest process would be for you to generate an activation code based off your serial number which you can do with this website:
https://www.ni.com/my/s/support/offline-activation
Additionally, here's some other options on activation if you're still having errors:
https://www.ni.com/en/support/downloads/activate.html
Ali S.
Applications Engineering
(4,030 Views)
Ali.  That worked!  Using the web interface option I was able to get an activation code.  I entered it in and was able to activate my license on my new laptop.
Thank you!
oxfat
(4,025 Views)
Oxfat,
 Happy to help!
Ali S.
(4,018 Views)
