Ports not showing up - NI 9482
I am making a program that can remotely switch ports on and off for the NI 9482 module. My issue is that the DAQ Assistant only recognizes port 0 and its four channels.
I am able to remotely switch port 0 using LabVIEW but I also need to be able to switch port 1.
Is there any setting I can change that allows me to view and use other ports?
Thank you.
(567 Views)
Program C Series Relay Output Module with DAQmx
  • port output uses one channel for all lines.
  • line output uses one channel for each line.
Control Lead | Intelline Inc
(524 Views)
For my program I need to be able to access line 1-4 for ports 0 and 1. I notice only lines for port 0 are showing up for you, and that is the same issue I have. Is there a way to access line outputs for port 1?
(499 Views)
Hi RAT,
Which "port1" are you talking about?
The NI9482 is a 4 channel DO module, so you get 4 lines in one port as shown in the images above!
General recommendation: read the manual… 😄
(488 Views)
this module NI 8482 has only 4 lines, on port 0. there is no port 1.
When you write "1" on the  line 0 the module closes the connection between CH0a with CH0b.
(487 Views)
This module does not have port 1.
(466 Views)
