10-11-2024 11:51 AM
I am working on to trigger SMU to start current capture by a pattern burst? Would you be able to give me sample on how to do this.
10-11-2024 04:07 PM
Please elaborate more, do you want to capture current at certain locations during a pattern burst of profile the current through the whole pattern burst?
10-11-2024 09:05 PM
Thank you for responding. Correct. What I am planning to do is if there is a opcode that I can use on digital pattern editor such that when I burst a pattern I can automatically send a PXI trig measure trigger to SMU to start current capture. The reason for this is I need the exact timing and I am capturing really small current pulse. Just wondering if there are examples.
10-12-2024 09:47 AM
Here is the high-level concept. See if you can translate this into code,
For this example, let us use event0, PXI_Trig0 and 6571's alias be DPI_6571
