When I download Linx version 1.0.0.59 I get a message:"This package is not compatible with your operating system or any LabVIEW version installed on your computer". I am running LabVIEW 2012 SP1 on Windows 7 64 bit.
Message 1 of 12
(5,056 Views)
Holy long title, batman!
I'm pretty sure there's a version 2 out that might fix any compatibility issues. If that doesn't fix it, you should ask on the LINX forum rather than here.
Cheers
Message 2 of 12
(5,045 Views)
What version of VI Package Manager do you have?
Make sure you have the latest version of VIPM installed. VIPM throws that error if you try to install a package that was built with a newer version of VIPM.
The documentation on the package shows that it should work otherwise:
LVH - LINX v1.0.0.59 by LVH
Released On: Tue, 01 Apr 2014 15:03:01 -0500
Author: Sam Kristoff
Copyright: Copyright (c) 2014, LVH
License: MIT
Compatible LabVIEW Versions: >= 2011.
Compatible OS Versions: ALL.
Repository Name: NI LabVIEW Tools Network
Description:
LINX provides a unified LabVIEW API for interfacing with common embedded platforms such as chipKIT, Arduino, myRIO and more. LINX's hardware abstraction layer provides support for hardware peripherals as well as common sensors, and enables the same code to interface with a chipKIT or Arduino and run headlessly on myRIO with no modifications.
Release Notes:
Updated firmware wizard to deploy faster.
Added (tested working) support for Mega2560 and Leonardo.
This Package depends on these other packages:
LVH - Toolbox >= 1.0.0.24
Cheers
Message 5 of 12
(5,017 Views)
Go to Help >> Check for VIPM Update from within VIPM. Mine is build 1963, so it looks like you can upgrade slightly.
Cheers
Message 7 of 12
(4,996 Views)
Why don't you install the newest version? 1.0.0.59 is the oldest listed in the VIPM. Why not use 2.0?
Cheers
Message 9 of 12
(4,974 Views)
