how do I discart the firsts sample readings of my NI and plot the rest in a graph
Run your VI until the graph contains data. Stop the vi, right click the graph terminal and select "create constant". Save the vi and attach it here.
Message 11 of 22
(886 Views)
Here it is,
Sorry that it took so long, I had a problem with my pressure transducer.
Hope you can still help me.
What I really want to do is match a cycle of pressure with a cycle of the cossine function in a way that the first value of the pressure is the minimum value of the wave.
Message 12 of 22
(863 Views)
Your diagram constant is empty. Did you run the VI before creating the constant?
Message 13 of 22
(859 Views)
Yes I did.
I run it, clicked on creat -> constant on the  XYgraph exit (at block diagram) then saved it.
Message 14 of 22
(857 Views)
Right-click on the xy graph terminal labeled "PV diagram" (all the way on the right), not elsewhere. Then make sure the diagram constant is NOT empty.
Message 15 of 22
(850 Views)
Here it is.
Message 16 of 22
(845 Views)
Here's how to discard the points up to the maxY.
(Of course all you need to do is retain the second plot)
Message 17 of 22
(837 Views)
This is great.
But it isn`t what I really need.
I need to obtain the data after the maximum point of the pressure (waveform graph)
My PV diagram should have an oval shape.
Message 18 of 22
(831 Views)
I want the circled data to go to the PV diagram
Message 19 of 22
(829 Views)
What is the t0 and dt for the graph? You need to set that, then just wire the waveform graph as indicated.
Message 20 of 22
(828 Views)
