07-11-2013 04:15 PM - edited 07-16-2013 02:58 PM
Run your VI until the graph contains data. Stop the vi, right click the graph terminal and select "create constant". Save the vi and attach it here.
07-16-2013 02:39 PM
Here it is,
Sorry that it took so long, I had a problem with my pressure transducer.
Hope you can still help me.
What I really want to do is match a cycle of pressure with a cycle of the cossine function in a way that the first value of the pressure is the minimum value of the wave.
07-16-2013 02:59 PM
Your diagram constant is empty. Did you run the VI before creating the constant?
07-16-2013 03:08 PM
Yes I did.
I run it, clicked on creat -> constant on the XYgraph exit (at block diagram) then saved it.
07-16-2013 03:17 PM - edited 07-16-2013 03:17 PM
Right-click on the xy graph terminal labeled "PV diagram" (all the way on the right), not elsewhere. Then make sure the diagram constant is NOT empty.
07-16-2013 03:22 PM
Here it is.
07-16-2013 03:32 PM - edited 07-16-2013 03:36 PM
Here's how to discard the points up to the maxY.
(Of course all you need to do is retain the second plot)
07-16-2013 03:40 PM
This is great.
But it isn`t what I really need.
I need to obtain the data after the maximum point of the pressure (waveform graph)
My PV diagram should have an oval shape.
07-16-2013 03:43 PM
I want the circled data to go to the PV diagram
07-16-2013 03:46 PM
What is the t0 and dt for the graph? You need to set that, then just wire the waveform graph as indicated.
