mask test remotely with LeCroy 6030 oscilloscopes
Hello everybody !
For an automated test I must use a mask test for one channel, seeing the PASS/FAIL result.
I am using WM-RCM-E_Rev_D_902208( remote manual ).pdf but I didn't saw any remote command for controlling the mask and to read the mask test result (pass or fail).
If possible I remotely want to load a mask from the oscilloscope (or directly from the computer), set the test conditions and read back the mask test result.
There are somewhere a list with these commands available? If yes would you send it to me please.
Do you have other example/suggestions for me how to do that?
Thank you!
Message 1 of 10
(4,540 Views)
Message 2 of 10
(4,536 Views)
Accepted by Nicku
Hi Nicu,
Use the VBS command to send in the automation strings for the P/F functionality you are wanting to access. The automation strings can be found by running XStream Browser; there is a shortcut to this application on the desktop of the scope. XStream Browser shows the automation interface for the scope; connect to the "local scope", and then navigate to PassFail/Q1. At the Q1 level you will see the overall settings. Go to the Operator folder to see additional details.
Some examples:
To specify which mask file:
VBS 'app.PassFail.Q1.Operator.Filename = "D:\Masks\100BaseT.msk" '
To setup the condition:
VBS 'app.PassFail.Q1.Operator.Condition = "AnyOut" '
To readback the result of Q1:
VBS? 'return=app.PassFail.Q1.Out.Result.Value' (returns 0 for false, -1 for true)
To readback the overall P/F result
VBS? 'return=app.PassFail.LastPass.Result.Value' (returns 0 for false, -1 for true)
Don't hesitate to contact me if you have any additional questions.
Best Regards,
Alan
Alan Blankman, Software Engineer
Teledyne LeCroy
800-425-2000
http://www.teledynelecroy.com
alan.blankman@teledyne.com
Message 3 of 10
(4,518 Views)
Thank you all!
The problem is solved.
Smiley Happy
Message 4 of 10
(4,506 Views)
Never mind marking an accepted solution but can atleast share what you did to solve it and then mark it as an accepted one?:smileywink:
Message 5 of 10
(4,497 Views)
Sorry, my mistake!
I didn't know how to mark that using VBS commands is the solution.
At this moment I don't know how to delete the check from accepted solution from my side and put it in the Alan replay.
Message 6 of 10
(4,472 Views)
Message 7 of 10
(4,467 Views)
nicku,
Thanks :smileywink:
Message 8 of 10
(4,416 Views)
Hi Alan,
This post might be too old but i have some issue regarding the mask test and hope you can advise.
Attached is my code but i cannot get the response sometimes and even got an error message at the scope.
 Can you please advise? Thank you.
Crystal
Message 9 of 10
(3,033 Views)
Hi Crystal -  I'm no longer in tech support, and kindly ask that you call your local Applications Engineer for assistance.  If you are in the USA, you can call 800-553-2769 for tech support.  Our "Contact Us" page has phone numbers/email addresses for support if you are outside of the US.
My quick thought on the issue...  Is it possible that you are encountering a Windows permissions issue?  Perhaps the error message is occurring because the file is already open?
Best Regards,
Alan
Teledyne LeCroy
800-425-2000
Message 10 of 10
(3,019 Views)
