08-27-2019 04:02 AM
Hello everyone !
I'm having some problems with this function contour analysis. This function is functional extracts a single, best contour from an image. But I want to take out many contour. Is there any way to get it out?
Thank you.
08-31-2019 09:01 PM
Can anyone help me solve this problem. I'm stuck on this issue
10-08-2019 11:13 AM
vuka,
I know that this post is pretty old, so not sure if you've figured it out already. I'm a little confused about what you are trying to accomplish. Do you want to analyze each of the shapes in this image separately? If so, you will need to call 4 different Contour Analysis functions and specify a different ROI for each on that only contains the one shape you want to analyze.
-Jordan
