Machine Vision
Error at device initializationIMAQdx Open Camera.vi
When ever vision system is started, this error occurs Error at device initializationIMAQdx Open Camera.vi and application do not initialize.
What is the cause this issue??
(951 Views)
Hi OAJ
Are you able to view the camera and acquire from it within MAX?  Also, what version of IMAQdx do you have installed?  The driver versions can be found in MAX under the software tab.  Because this all occured after an upgrade to a newer version of LabVIEW, I would suggest re-installing the Device Drivers CD, then re-installing the Vision Acquisition Software.
Regards)
(834 Views)
