Hi OAJ,
Are you able to view the camera and acquire from it within MAX? Also, what version of IMAQdx do you have installed? The driver versions can be found in MAX under the software tab. Because this all occured after an upgrade to a newer version of LabVIEW, I would suggest re-installing the Device Drivers CD, then re-installing the Vision Acquisition Software.
Regards)
