10-04-2006 11:29 AM
Dan,
The Pulnix TM-4100CL specifies that the partial scan mode you're using runs at 28 fps. Can you rerun the AVI example using this frame rate?
Ryan F.
10-04-2006 11:49 AM
10-04-2006 12:09 PM
10-04-2006 01:32 PM
10-05-2006 10:29 AM
Dan,
All Grab operations time out eventually? Does it time out in approximately the same time for all scan modes or does it take longer to time out for some than others?
Ryan F.
10-05-2006 11:36 AM
10-06-2006 03:01 PM
Hi Dan,
My name is Chris, and I'm an Applications Engineer here at National Instruments. I will be working on this issue along with R&D, and we think it would be best to get this camera in house. Would it be alright if we get in direct contact with you to speed up the process? Thanks.
-Chris
09-15-2009 01:01 PM
09-16-2009 09:09 PM
12-04-2018 01:15 PM
what we need is an answer. what good is this forum if the answers are private?
