Machine Vision
Problem with horizontal scrolling during "grab" in MAX using Pulnix TM-4100CL and PCI-1428
Dan,
The Pulnix TM-4100CL specifies that the partial scan mode you're using runs at 28 fps.  Can you rerun the AVI example using this frame rate?
Ryan F.
Message 11 of 21
(2,349 Views)
Ryan,
When I attempt to acquire at a higher frame rate, such as 28fps I get a timeout error.  I even tried 20 fps and I still got a timeout error.  Even though when I scroll through the 5 images in the front panel they all seem to be there before the timeout error pops up.
This could have something to do with the VI waiting for the "Acquisition Done" signal and it not occuring until the timeout period is over even though the frames are already in memory.  The acquisition done would always wait for the timeout period before it transitioned.  I had encountered this problem earlier with 1 of the sequence VI's but managed to work around it by using X occurences of the "frame done" signal instead , where X was the number of frames in the sequence.  Could the fact that the acquisition done signal is not behaving properly have something to with the framegrabber hardware or the camerafile?
As I was not able to produce a new AVI at the higher famerate that you asked for, is there any other information that you need to help in the troubleshooting?
Dan
Message 12 of 21
(2,347 Views)
Dan,
When you Grab in MAX what frame rate does it report?  This is shown down in the MAX status bar (View->Status Bar) at the bottom right.  You'll see the Frames per second: (displayed, acquired).
Ryan F.
Message 13 of 21
(2,344 Views)
Ryan,
Scan mode A (2048x2048) => 15 fps acquired, 15 fps displayed
Scan mode B (2048x1000) => 28 fps, 28 fps
Scan mode C (2048x500)   => 49 fps, 49 fps
Scan mode D (2048x250)   => 79 fps, 79 fps
This is of course before the grab times out which always happens eventually.
- Dan
Message 14 of 21
(2,340 Views)
Dan,
All Grab operations time out eventually?  Does it time out in approximately the same time for all scan modes or does it take longer to time out for some than others?
Ryan F.
Message 15 of 21
(2,329 Views)
Ryan,
Yes all grabs timeout eventually.  Scan mode A times out the fastest, then B, then C, then D.
- Dan
Message 16 of 21
(2,325 Views)
Hi Dan,
My name is Chris, and I'm an Applications Engineer here at National Instruments.  I will be working on this issue along with R&D, and we think it would be best to get this camera in house.  Would it be alright if we get in direct contact with you to speed up the process?  Thanks.
-Chris
Message 17 of 21
(2,311 Views)
Im having a similar problem with a pixelink camera. How did this resolve?...no point in this threads if they are resolved off-line
Message 18 of 21
(1,754 Views)
I could not find history of this in our database. Please post details of your issue and we can try to help you out.
Vivek Nath
Machine Vision
Message 19 of 21
(1,725 Views)
what we need is an answer. what good is this forum if the answers are private?
Message 20 of 21
(828 Views)
