10-05-2023 04:56 PM
Hello all,
I have an inspection that was created using NI Vision Builder 2020. Meanwhile I worked on that inspection using a 2023 Vision Builder version. After that, I cant run/open the file in another computer that has the 2020 version. Is there a way to save the file in order for it to work on the 2020 software again?
10-05-2023 09:34 PM
On the 2023 you can save "File / Save For Previous Version" You can go back to 8.0, however some features might be broken. They are pretty easy to find and correct.
Good luck!
10-06-2023 12:56 PM
Thank you for your reply. Unfortunately that option does not show in my program..
After searching a bit more I found that, according to NI, these vbai files cannot be saved to previous versions 😫 frustrating
10-08-2023 07:16 PM
Ah.. I misunderstood. LabVIEW can save to previous programs, but not Vision Builder.. I currently run LabVIEW 2021 SP1. If your vision builder is that era or older, you can send the file and I can convert it for you.
I have frozen my version of LabVIEW, as I want to actually own my software, and not rent it. So far none of my customers have complained.
Good luck
Robert
