Machine Vision
Where is NC-SI Port on IC-3173
Hi
I use 3173 FPGA I/O, there are four NC-SI ports, but it is not Iso Input, iso Output,  Differential I/O or TTL I/O. Which hardware dose it control? POE port?
CLD
CAU
(2,986 Views)
The NC-SI stands for Network Controller Sideband Interface and it would be for the Ethernet.
https://www.intel.com/content/dam/www/public/us/en/documents/application-notes/nc-si-overview-and-pe...
(2,964 Views)
Accepted by lizhuo_lin
Those nodes allow the FPGA to send and receive traffic from the network ports, bypassing the system’s CPU. Using these nodes directly takes some significant effort.
The Vision-RIO Driver API makes use of this internally to determinstically trigger GigE Vision cameras over Ethernet, without any extra cables.
(2,956 Views)
