11-21-2006 12:48 AM
11-21-2006 02:50 PM
Greetings Serhat,
Please try the following procedure to resolve this problem:
1) Exit Measurement & Automation Explorer (if open) and close all National Instruments programs.
2) Delete the "C:\Program Files\National Instruments\MAX\Data" directory (or cut it from this location and paste it to your desktop)
If you are unable to delete all the files in MAX directory. End process nimxs.exe from Task Manager, then delete the "C:\Program Files\National Instruments\MAX\Data" folder.
The key to fix this error is to completely delete all the files in the "Data" directory.
3) Restart the computer.
Let me know if this fixes the error...
Nicholas B, National Instruments
11-22-2006 12:05 AM
11-22-2006 08:47 AM
09-03-2008 06:32 AM
hi nicholas.
i m using Labview 8.6 with SC2345 and NI DAQPad 6015 with usb connection. i m contantly getting error 88302, 200016 and 200560. and also when i am trying to send an output analog signal i am unable to do it. i was unable 2 activate my labview cos when the DVD was recieved by my company no serial number was printed. is it have to do something with the activation. and also i have tried to use the evaluation version from this website but it is not working with tht either.
please suggest me wat to do ...
thanks
09-04-2008 05:27 PM
Hi C007,
This article should help with part of the issue that you are seeing. It should not have anything to do with the evaluation version of LabVIEW. If you continue to get errors, it would be helpful if you could describe what you are trying to do when you see this error. In addition, it would be helpful if you started a new thread for this issue since it is probably different than the prior issue.
Kent
Applications Engineer
