Hi Wes,
If the instrument were still present, it would be under Devices and Interfaces in MAX. It would be shown as in the
attached jpg.
Do you have a VI Logger Task that references an ENET device? This could be a reason for the error.
If not, your database may have been corrupted. You can try solution 4 from the KnowledgeBase article referenced above to remove the corruption:
How Do I Recover From MAX Database Corruption?http://digital.ni.com/public.nsf/websearch/86256F0E001DA9FF86256FFD005B827C?OpenDocument
This would delete your configuration in MAX, but should fix the problem. If your configuration is not extensive and is easily recreateable, this can be a quick solution.
John Bongaarts
