NI Package Management Idea Exchange
cy...
NIPM to install packages from where it was requested
Status: New
Hi forum, would like to propose the idea above 👆
A brief explanation of the the idea would be, if the NIPM package is opened from an ISO of a local repository (running install.exe from a mounted ISO), NIPM should install the entire package from that ISO, unless the package have a mismatch inside the ISO. this applies for offline installers, where user is responsible to check the ISO's hash once it is downloaded.
if the package installation is requested from the feed list inside of NIPM, only then it should download from NI through the internet
just an idea... to reduce possible installation errors
CY (expired CLAD)
