NI TestStand Idea Exchange
warren_scott
Improve error checking when connecting LabVIEW Clusters and TestStand Types
Status: Completed
Hey Warren,
I'm not exactly sure when this behavior changed, but in TestStand 2019 i'm getting an edit time Error as well as a sequence analyzer.
I suspect that this was completed a while back and nobody closed it. Let me know if you still see the behavior.
Trent
Recently ran into a problem when I was configuring a LabVIEW module that passed in/out clusters/types.  I had a mistake in my code that the teststand data type was not configured to allow it to pass to LabVIEW clusters, but the problem was not as obvious as I thought it should be.
Here's what I had:
And when I click on the red checkmark "check expression" for "Cluster", it shows up as "No Errors".  Everything looks great, right?  Well, it isn't.
It's not until I expand "Cluster" to show the elements that I see that there are connectivity problems.
It would be nice if "Locals.mylocal" expression would turn RED and show a "check expression error" if any of it's children also had a connection problem (specifically in this case that the type in TestStand was not configured to allow passing to LabVIEW clusters).  This way it would be a lot easier to see.
Even worse, this problem is NOT found by sequence analyzer -- it's left to be found at runtime.
I know this is all because I had a bug/mistake in my code, but it would be a lot easier to track down and fix if these changes were made.
3 Comments
Lars_L
NI Employee (retired)
Status changed to: Under Consideration
WireWeaver
Status changed to: Completed
Hey Warren,
Trent
warren_scott
Trent --
I did a quick check through sequence editor in TS2019 and I agree that this issue has been fixed.  Thanks to the team for getting this fixed/improved/addressed!
Warren
