Recently ran into a problem when I was configuring a LabVIEW module that passed in/out clusters/types. I had a mistake in my code that the teststand data type was not configured to allow it to pass to LabVIEW clusters, but the problem was not as obvious as I thought it should be.
Here's what I had:
And when I click on the red checkmark "check expression" for "Cluster", it shows up as "No Errors". Everything looks great, right? Well, it isn't.
It's not until I expand "Cluster" to show the elements that I see that there are connectivity problems.
It would be nice if "Locals.mylocal" expression would turn RED and show a "check expression error" if any of it's children also had a connection problem (specifically in this case that the type in TestStand was not configured to allow passing to LabVIEW clusters). This way it would be a lot easier to see.
Even worse, this problem is NOT found by sequence analyzer -- it's left to be found at runtime.
I know this is all because I had a bug/mistake in my code, but it would be a lot easier to track down and fix if these changes were made.
Hey Warren,
I'm not exactly sure when this behavior changed, but in TestStand 2019 i'm getting an edit time Error as well as a sequence analyzer.
I suspect that this was completed a while back and nobody closed it. Let me know if you still see the behavior.
Trent
