09-24-2009 08:45 AM
i'm using LabVIEW to realize my custom OI. I already succeded to load and run a selected sequence.
What i want to do now is to get and, eventually, set each sequence parameter (name, value, type) listed in: "Sequence manager" -> "Variables" -> "Parameters" . I would like to this after the sequence has been loaded and before it is run... but i don't know how!
Suggestions? 😉
09-25-2009 08:16 AM
Hi Arco,
let me verify if I understood your post correctly:
You can take a look to this example too:
C:\Documents and Settings\All Users\Documents\National Instruments\TestStand 4.x\Examples\AccessingPropertiesUsingAPI\UsingLabVIEW
Hope this helps,
Best Regards,
Fabio
10-07-2009 07:00 AM
I think that the appropriate solution would stand at the following link:
http://digital.ni.com/public.nsf/websearch/5C08014017AA895686256DD6008323FB?OpenDocument
