Get sequence parameters...
i'm using LabVIEW to realize my custom OI. I already succeded to load and run a selected sequence.
What i want to do now is to get and, eventually, set each sequence parameter (name, value, type) listed in: "Sequence manager" -> "Variables" -> "Parameters" . I would like to this after the sequence has been loaded and before it is run... but i don't know how!
Suggestions?  😉
(3,586 Views)
Hi Arco,
let me verify if I understood your post correctly:
  1. When you say "set each sequence parameter (name, value, type) listed in: "Sequence manager" -> "Variables" -> "Parameters", do you mean setting properties under "parameters" container programmatically from the OI? If so, all you have to do is to access TS properties through the TestStand API (there are 2 VIs, "TestStand - Set Property Value" and "TestStand - Get Property Value" located under Functions -> TestStand)
 You can take a look to this example too:
C:\Documents and Settings\All Users\Documents\National Instruments\TestStand 4.x\Examples\AccessingPropertiesUsingAPI\UsingLabVIEW
Hope this helps,
Best Regards,
Fabio
Fabio M.
NI
Principal Engineer
(3,566 Views)
Accepted by aRCo
I think that the appropriate solution would stand at the following link:
http://digital.ni.com/public.nsf/websearch/5C08014017AA895686256DD6008323FB?OpenDocument
Regards
(3,495 Views)
