How to perform action after report is generated?
After a report is generated, we need to automatically make a copy of the report in a different location. What is the best way to do that?
(875 Views)
Accepted by christopher12345
Override the PostUUT Callback or the Process Cleanup Callback and do it in one of those.
If you are using a later version of TestStand you can just add another report and point it to a different location.  That way TestStand will just generate 2 reports at once.
jigg
CTA, CLA
testeract.com
(846 Views)
Another option is to use the GetReportFilePath callback.
Programmatically Determine the File Path and File Name of a TestStand Report - NI
Anand Jain
NI
(840 Views)
