01-25-2022 09:21 AM
After a report is generated, we need to automatically make a copy of the report in a different location. What is the best way to do that?
01-26-2022 04:42 PM
Override the PostUUT Callback or the Process Cleanup Callback and do it in one of those.
If you are using a later version of TestStand you can just add another report and point it to a different location. That way TestStand will just generate 2 reports at once.
01-26-2022 04:49 PM
Another option is to use the GetReportFilePath callback.
Programmatically Determine the File Path and File Name of a TestStand Report - NI
Anand Jain
NI
