02-19-2010 08:14 AM
Hi, I installed TS4.2.1 and LabWindowsCVI9.0. When I try to complile the modelsupport2.dll I get several errors in "BaseTsd.h", "WinNT.h".
Do you have any idea?
Thanks.
02-19-2010 08:35 AM
did you installed the window sdk for labwindows ?
you can find it into the labwindows disk
02-22-2010 10:11 AM
Hi, I am not sure. 1st time I did the typical installation, then I uninstalled and I did a custom installation but I did not find the installation for the sdk. I do not have the disk for CVI. I have 3dvd with the entire NI suite.
But I discovered that I can compile and build the modelsupport2.dll installed with TS 3.5.
Then the CVI 2009 can compile and build the modelsupporte2.dll installed with TS 3.5 but not the one installed with TS 4.2.1.
what could be changed?
Thanks.
