NI TestStand 2023Q4 32bit and Python 3.10 32bit problem
I have a problem getting Python to work with my 2023Q4 TestStand. In Step settings pane, there should be button with text "Configure Python Step". In my button reads "String not found in the language resource files" . See picture below. Any ideas how to fix this?
Message 1 of 9
(418 Views)
Looks like a part of your localization is missing.
Are you working with TestStand System language English?
Are you using TestStand Environments?
Message 2 of 9
(413 Views)
My language is english. I am not sure what TestStand Environments is, but I guess I dont use it... 🙂
I haven't Activated my TestStand product yet, so I am running still on trial period. (If this could be the reason?)
Message 3 of 9
(409 Views)
The message you are seeing basically says that the localization string wasn't found.
Those strings reside in %TestStand64%\Components\English
This really only happens for the Python Steps? I'd expect this also to happen with other adapters
Message 4 of 9
(376 Views)
I see configuration setting files (many of those named xxxStrings), in path C:\Program Files (x86)\National Instruments\TestStand 2023\Components\Language\English
Any idea how to fix this issue?
Message 5 of 9
(370 Views)
AFAIK the Step Pane strings reside in SequenceEditorStrings,ini
On my computer the according section looks like this:
[STEP_SETTINGS]
CAPTION = "Step Settings"
CAPTION_WITH_STEPNAMES = "Step Settings for %1"
PROPERTIES_TAB = "Properties"
MODULE_TAB = "Module"
TYPE_TAB = "Type"
GENERAL_SETTINGS = "General"
RUN_SETTINGS = "Run Options"
LOOP_SETTINGS = "Looping"
POSTACTION_SETTINGS = "Post Actions"
SYNC_SETTINGS = "Synchronization"
SWITCH_SETTINGS = "Switching"
EXPR_SETTINGS = "Expressions"
PRECOND_SETTINGS = "Preconditions"
ADDITIONAL_RESULTS_SETTINGS = "Additional Results"
CUSTOM_PROPERTIES = "Property Browser"
REQUIREMENTS_SETTINGS = "Requirements"
CLOSE_BUTTON_TEXT = "&Close"
HELP_BUTTON_TEXT = "&Help"
NO_STEPS_SELECTED_MSG = "There are no steps selected."
EMPTY_STEP_NAME_TEXT = "<Empty Name>"
Yet if there is a problem with this section / file, it should affect all StepTypes / Adaptors, not only Python
Message 6 of 9
(346 Views)
That section looks exact same in my computer.
Message 7 of 9
(298 Views)
Took another look at the screenshot of your first post:
the palette on the left side says, that this step is of type NI_Python, which seems to be a Custom Step Type.
A short (search machine of your choice) query returns https://www.ni.com/de/support/downloads/software-products/download.python-step-types-for-teststand.h...
Without further investigations, I suspect this was the initial Python integration for TestStand which is kinda non-standard / out of date nowadays.
I see two options:
1.) re-install this package hoping for the localization to come back
2.) change your code to the current step types with the (as of now) full Python support
Note: Option 1.) might seem tmpting to do since it might work very quickly, on the other hand you are setting up a new system right now... why not doing things right instead of increasing technical debts?
Message 8 of 9
(295 Views)
Accepted by topic author Oli_Wachno
Problem solved. I copied NiPythonStepTypeStrings.ini file to path --> C:\Users\Public\Documents\National Instruments\TestStand 2023 (32-bit)\Components\Language\English
Now it works... 🙂
Message 9 of 9
(274 Views)
