PXI
Can only see half the cards in PXIe-1084 chassis
I am using RT Linux with PXIe-8821 and PXIe-1084 but only slots 2-7 are showing up in NI MAX.
I tried swapping a card from slot 8 with slot 2 and it shows up in NI MAX.
This controller and chassis are brand new.
Any ideas?
(236 Views)
How about drivers?
Santhosh
Soliton Technologies
(228 Views)
HTTP Client with SSL Support
LabVIEW Real-Time
Network Variable Engine
NI System Configuration
NI Web Based Configuration and Monitoring
NI-DAQmx
NI-DAQmx OPC Server
NI-SWITCH
NI-VISA
NI-WATCHDOG
PXI Platform Services
Run-Time Engine for Web Services
Variable Client Support
WebDAV Server
The card family is the PXI-6511/6512/6513 and each card shows up in NI MAX when they are installed in slots 2-7 but not in 8-16
(215 Views)
Accepted by topic author aliciacantcodeg
Occam's Razor: The new chassis was a dud
(143 Views)
