ErnieH
Ability to embed VI's and type definitions into other VI's and save them as a single file.
Status: Declined
Already implemented in LabVIEW. Available in LabVIEW 2010.
  • Complete vi with embedded sub vi's and type defs would be in one file. Non embedded vi's would have file names be as normal.
  • Embedded VI's could be present to top level vi as if it was on the block diagram or behave like a normal VI.
  • Embedded VI's would be local to the top level VI.  Not visible from outside VI's.
  • Would reduce the number of 'glue logic' vi's in a project. Why create another file if not needed?
  • Would help reduce cross linking problems.
  • Would make it easier to save versions of a more complicated function that has sub vi's.
  • Would simplify code sharing. Pull it from another project. Start with the  top level VI you are interested in, assign sub vi's as an embedded type. Send the file to a colleague. They put it on their block diagram. It is self contained. They can then go in and customize it if they choose.
  • Send the VI to anyone you want without worrying about cross linking or vi file names.
  • Embedded VI's would open for editing, just like regular VI's. Could be saved as regular VI's.
  • If embedded VI was at the same level as the diagram code, you could use property nodes that directly interact with front panel controls without using references.
  • Feel free to add any advantages, improvements on this idea, or problems this may help that are not listed here.
5 Comments
tst
Knight of NI Knight of NI
Knight of NI
The current beta has a feature which may answer some of these requirements. I suggest you enroll in it to check it out.
___________________
Try to take over the world!
tst
Knight of NI
In case anyone is wondering, the feature I was refering to was the packed project library and now that 2010 is out you can check it out.
___________________
Todd S.
NI Employee (retired)
Status changed to: Completed
Completed in LabVIEW 2010
Todd S.
LabVIEW Community Manager
G-Money
Available in NI LabVIEW 2010
G-Money
Status changed to: Declined
