CL_eisenwr
Add Assert Set and Assert Map
Status: Declined
Declined for reasons listed in AristosQueue's replies
From trying to make a malleable VI for some set/map functionality, I cannot seem to find a good way to cause the VIM call to be broken for when the input is not a set/map. It would be helpful to have a Asset Set and Assert Map method added to the Assert Type palette for this.
Related post
__________________________________
Bill Eisenhower
Certified LabVIEW & TestStand Developer
3 Comments
AristosQueue (NI)
NI Employee (retired)
Just use the set or map operations with your input. Any non-set/non-map input that tries to wire to those functions will fail. You don't need an assert.
Asserts are almost never needed in writing VIMs. For some really generic operations, they have value, but usually, just do your operation.
AristosQueue (NI)
For examples... see the Sets and Maps palettes (respectively). They both have VIMs that operate on sets or maps (respectively)... none of them use assert nodes.
Darren
Proven Zealot
Status changed to: Declined
