When performing some scripting I found it handy at times to create the block diagram objects, use a Cut Selection method on the selection objects, and then I would have the image of the objects in my clipboard. The cases when I needed this I also needed to delete the scripted objects so this one method performed the delete, and allowed me to have an image of the scripted code.
When doing the same operations on the front panel I noticed there isn't a Cut Selection method on either the panel or pane classes and made a post about it.
http://forums.ni.com/t5/LabVIEW/Missing-Cut-Selection-Front-Panel-Method/m-p/3190560
This idea is to create the Cut Selection method on either the pane or panel class (or both I don't really care) which operates like like the Copy Selection, and Delete would today.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
