AlexElb
Add Target to VI Analyzer (API)
Status: New
When manually analysing a project, we can set the target in which the VIs should be loaded. Unfortunately, VIs with RT code are often broken under windows, leading to wrong test results, or even worse, pop-ups asking for VIs.
Please add an Application Reference Input for the VIAn Run.v.
Maybe this option could also be useful set in the VI Analyzer configuration file?
Proud developer at Hampel Software Engineering where we turn '404 not found' into '200 OK'. Join us on Discord
1 Comment
Darren
Proven Zealot
I published an unofficial (i.e. not supported by NI) solution to this issue here:
https://forums.ni.com/t5/Community-Documents/VIAn-Run-with-optional-App-Reference-vi/ta-p/4259706
