I have just had my first look at some sample VIs that were demonstrating the use of channel wires and I have seen channel wires going from left to right and also from right to left in the block diagram. It was my understanding that LabVIEW best programing practice was to avoid backward wires. The VI Analyzer actually tests for the number of occurrences of backward wires. If the new programing best practice is going to allow backward channel wires, then to avoid confusion about the direction of data flow the channel wires should have a visual indication for the direction of data flow. My suggestion would be a chevron design that indicated the direction of data flow, see attached file.
[admin edit 2016-09-15] Changed title of idea from 'Channel Wires' to something more descriptive.
Declined for reasons listed here: http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Add-direction-arrows-to-the-depiction-of-channel-wires...
