User | Kudos |
5 | |
2 | |
2 | |
1 | |
1 |
For a table, the "Export data to Excel" right-click menu export only the contents of the table are exported to MS Excel. The column headers are not exported.
I've already discussed here this behavior, and the reason is that only the table contents are considered as "data".
But I think that if you have a lot of columns, the data without their description is not so useful.
For this reason I propose that a new right-click menu item called "Export table to Excel" should be added for tables, and this new function should export the data together with the column headers.
