tst
Add sparse enums to LabVIEW
Status: Declined
National Instruments will not be implementing this idea in LabVIEW 20xx. It is currently the feature backlog for LabVIEW NXG.
Today, the enum data type in LabVIEW only allows having sequential numeric values (0, 1, 2, 3, etc.).
It would be very useful to have sparse enums, meaning enums which can have custom numeric values assigned to their strings, just like you can do today with rings.
If you want an example where this will be useful, think of error codes - this would allow you to use an enum on the diagram to select the error, or in a case structure.
___________________
Try to take over the world!
28 Comments
tst
Knight of NI Knight of NI
Knight of NI
And, while we're at it, it would be useful if these enums could also have negative values.
___________________
JackDunaway
Trusted Enthusiast
Even though this is a duplicate post (http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Enum-Datatypes/idi-p/925056#A468), KUDOS because I would like to see this feature.
Ray.R
Knight of NI
I like your example with error codes.  Such a feature would be awesome.  Kudos.
waldemar.hersacher
In my opinion an enum does not only display "Red", Green", "Blue" it is "Red", Green", "Blue". This is even reflected in the "Format into String" function. Connecting an enum will give "%s" as format specifier and not "%d".  If I need to associate number with strings I use a ring.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
hfettig
The problems with Rings is that they don't work well with type defs.
If you have a list of error codes in a typedef Ring and you add one extra number into that Ring typedef none of you already existing instances of this typedef are updated.
This is because the string is not a part of the datatype in a Ring. If you make it a strict typedef your controls and indicators get updated, but not your constants.
Therefore a sparse enum, preferable with the ability to use signed integers as well would be very useful.
tfritz
Maybe it would be good to add this as another datatype. Something like "Define" datatype. I'd also like the possibility to have multiple names for one value, something that I sometimes need in my programs and that is easy in C by doing either
typedef enum
    FOO = 0,
    BAR = 0,
    FOOBAR = 10
} foobar;
or
#define FOO       0
#define BAR        0
#define FOOBAR 10
chrisger
A LabVIEW equivalent for
#define FOO       0
#define BAR        "hello kitty"
#define FOOBAR <whatever>
would be great. I can imagine something like this:
- In the project tree there's a new menu item New->Definition. When the user selects this, a new definition is created. The user can rename the definition
- A definition is just like a Global Variable (i.e. a front panel to define the datatype and the value of the definition), but it is read-only
- the user can add the definition to block diagrams e.g. by drag'n'drop from the project tree. On the block diagram a definition is read only
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
tst
Knight of NI
Chris, this is basically the same as the CONST idea I posted here (whether we call it CONST or #define is irrelevant, since the differences don't apply to LV).
___________________
tst
Knight of NI
Also, if you want NI to implement these, you should click the big "kudos" star next to the suggestion, because that's part of the mechanism NI uses to prioritize these suggestions.
___________________
Patrick_P.
NI Employee (retired)
I actually ran into this problem today where I wanted to represent an enum from some C code in LV.  Of course the enum in C has something like the following:
enum {
read = 1 << 0
blue = 1 << 1
yellow =  1 << 2
... etc
It would be really nice to be able to represent this as an enum type in LV.  As someone already mentioned you could do this with a text ring but then none of the constants update anywhere on the diagram.  Kudos!
Pat P.
Software Engineer
