I've encountered a programming situation where I may need to call 'Match Regular Expression' where the regex is selected at runtime, and where that regex may potentially have a variable number of submatches to return. Unfortunately, right now, the submatch count is a compile-time decision based on how far out I grow the node. I can grow the node to some maximum number of submatches ever expected, and thankfully the node doesn't throw a runtime error if there are fewer, or greater, submatch expressions in the regex. I'm building the individual returns into a string array for further processing, but it would be much more versatile if the node could return the submatches with a properly-sized string array.
