Similar to how array and cluster constants on the block diagram can be edited, it would be useful to be able to edit map and set constants on the block diagram.
For example:
In the map constant above, the developer can scroll through and see all of the key value pairs in the map (plus an empty element at the end of the map).
It would be useful to also be able to edit the key-value pairs in the map (and add more key-value pairs to the map by changing the empty element at the end of the map).
