Hi all,
When LabVIEW prompts the user to locate a file and the file is inside an llb or lvlibp, long names of VIs are truncated in the title bar such that the user cannot easily verify which VI was prompted for. This ought to be fixed by allowing users to resize the window horizontally.
Here is an example wherein it is ambiguous which VI is being prompted for. Allowing horizontal resizing of the window would offer a straightforward fix that would help people with waning short term memory capabilities.
The relevant LabVIEW help topic unambiguously refers to this window as "File Dialog Box".
I am not referring to the File Dialog function on the palette.
Thanks as usual!
Mr. Jim
