When a third party add-on expires you get a dialog asking you to activate it, but the dialog does not offer you the option to remove it instead:
If would be nice to be able to select add-ons in the add-on list and then click a Remove/Uninstall button (and/or right-click). The current solution is to manually fire up the package manager and uninstall it from there (the remove button could alternatively (if needed /quicker to implement) call the package manager and tell it to start the removal of the selected packages.
