PROBLEM: There are often times when I decide I would like to include some code that is just outside of a structure. Currently in order to get it into the structure I have two options:
SOLUTION: Allow a control (or shift) when resizing a structure that causes the structure to capture the code rather than move it. This should not break any wires. In essence, it would be like redropping the structure.. Note this could also work in reverse. If you size a control smaller, it would exclude anything outside the new boundaries of the structure.
