Although it appears that the 2020 version of the Block Diagram Cleanup Tool (BDCT) does do a better job than its predecessors, I would still say that the BDCT’s results are still less than optimal. Most LabVIEW Idea Exchange posts concerning the BDCT talk about label positioning and alignment. Here I would like to focus on the issue of horizontal expansion of the block diagram and a holistic view of what LabVIEW features contribute to that effect.
Like most programmers, when developing a VI block diagram, I try to keep the diagram no more than one screen wide. I have learned a few tricks over the years that help manage horizontal expansion, such as resizing an object’s label so that the words appear on multiple lines before running the BDCT. This allows for some compression horizontally and allows for some growth vertically to compensate. Horizontal expansion of the block diagram is certainly expected to some extent because data flow happens left to right, of course; but it would seem logical to incorporate that knowledge into the BDCT algorithm to compensate and find ways to adjust the spacing so that the rearrangement creates more a bit more vertical expansion and less horizontal expansion—while still satisfying usual criteria such as no backwards-running wires.
Because data flow is horizontal, to help the BDCT work better, NI may want to think about what visual features—other than left-to-right data flow—contribute to a unnecessarily wide block diagram. I seldom have an issue with a block diagram becoming too tall. Admittedly, poor programming technique can result in too-wide block diagrams, but let’s look at a few other things. What elements of LabVIEW’s block diagram unnecessarily consume width? Here’s a few that I could think of:
To fully tackle this issue, I believe you have to look at things holistically and not just as potential improvements that could be made in the BDCT. Recognize that data flow is left-to-right horizontal and you will have long text names; you can’t really do anything about that. However, there are other things that could be done in LabVIEW feature-wise to help compensate for width-wise block diagram growth.
