So, i just changed a case from a string input to a boolean input. Ofcourse it gets broken with a red "1" in the case selector. That's logical.
Now i need to select the case selector and write False, then switch to the other and write True ...
Once both cases are correct i can r-click and switch them with a "Make this case False".
Improvement suggestion:
If having a boolean input, the Make this case True/False should be active for all cases always.
Even if you have multiple cases (it'll still be broken and you'll have to clear the extra cases)
